07-21-2023
01:57 PM
07-21-2023
02:07 PM
computergeek541
Hi I just in the middle of port in from Fido to PM. And a conversation box popped out said eSIM cannot be actived. Please help. Thank you.
07-21-2023 02:28 PM
Thx just sent them a message
07-21-2023 02:24 PM
no worry, PM support can probably get you a new QR code if it has not been activated yet.
Message them directly here:
07-21-2023 02:20 PM
Hi thank you, i use iPhone 12 mini
yes, just paid with credit card online
ive just tried scanQR to active, but still cannot. This is the screen shot it says, attached.
07-21-2023 02:01 PM
what phone do you have?
you completed the payment and phone number choosing/porting section?
If the auto eSIM setup with the app failed, try to manually scan the QR code, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
