01-16-2024
06:23 AM
01-16-2024
08:29 AM
computergeek541
My eSIM appeared to not transfer over properly. I could not receive calls or texts. I transferred from LUM. I was unable to receive a text message to log in to my account and verify my number. The given eSIM was deleted in an attempt to solve the problem, but again as I cannot log into my account I am unable to order a new one. I cannot wait a week for a hard copy SIM or a response. What do I do?
01-16-2024 06:44 AM
Thank you!
01-16-2024 06:42 AM - edited 01-16-2024 06:42 AM
@Summerhun But you can’t log in? So messages support using this direct link and maybe they can help you to rebuy eSIM
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
01-16-2024 06:40 AM
Thank you, I need my phone up and running as soon as possible so an eSIM would be preferable simply for the hope that I might be able to get it up and running more quickly.
01-16-2024 06:37 AM
@Summerhun No you need a new PM SIM card . SIM cards scan only be activated once and not be reused
01-16-2024 06:35 AM
Thank you I do have a SIM card from LUM would that suffice?
01-16-2024 06:30 AM
@Summerhun You need to re buy eSIM or get a physical sim . Personally I would go with physical sim you can buy one from Telus /koodo stores or from Amazon $4.99 right now . And get support to sim swap the number for you . Then the code will be sent to that new simcard and you will be able to log into your account
