e sim card
lxh
what is the procedure about active a new esim card.
Thanks!
1 REPLY 1
slusagm
If existing customer trying to move eSIM to another phone or change from current physical sim card to eSIM, just install PM app on the phone you want the eSIM, then login My Account, go to Account -> Purchase sim card -> eSIM and buy there.  The app will help install the eSIM
