10-29-2019 03:07 PM - edited 01-05-2022 07:47 AM
Is it possible to delete old APNs from my google pixel 2? I tried other sites for answers and I dont have "general" under my settings... anyone have any answers?
10-29-2019 03:22 PM
@steponme583 Is it the T-Mobile version? Are you running 10?
10-29-2019 03:13 PM
@steponme583 wrote:Is it possible to delete old APNs from my google pixel 2? I tried other sites for answers and I dont have "general" under my settings... anyone have any answers?
I don't have a Pixel 2. But for Android phone, you can delete old APNs, add a new one OR select a specific APN to use.
What is the issue with your APN?
You can check your APN setecting with the following link.
https://apn-canada.gishan.net/en/apn/public-mobile/google-pixel-2-xl
10-29-2019 03:11 PM - edited 10-29-2019 03:12 PM
@steponme583, APNs that are user generated can be edited and deleted. Ones that are stored on file cannot be edited or deleted. That said, having them around should not be an issue. Only the selected on is the one in use. If you are trying to locate the menu, use the search feature. Look for access point names.
