data usage
berntsenP
I know how to look to find out how much data I have been using but is there a way I can find what my data is used for? Thanks!
2 REPLIES 2
@berntsenP
Just login to your account and on the main page there is a current usage and if you click on the usage… it will have a breakdown of all your data usage, calls and texts.
@berntsenP  this is something you can check on your device.
Are you using iPhone or Android?
For iPhone, you CANNOT trace back your usage.  But you can reset your mobile data usage now and then monitor from this point.  It will tell you how much data you used and which app used the data
For Android, you can trace back the usage before, within the current 31 days.  You can go to Mobile Data Usage and change the cycle start date, it will update the info and will show you how much data used since that date and which app used:
