data Sony Xperia 3 Phone
trevorBraun
Hi I have a data plan with lots of room, My phone is a Sony Xperia 3.
My data has stopped working- I  can not access the internet via my phone
I can make calls. when I try to go on line
it says I am off line and try
turning off Aeroplane mode- i  have done that
turning on Mobile Data or WiFi-  works on wifi but not Mobile data- it appears on
checking signal in area- i have all bars and can make calls
really frustrating can someone help
7 REPLIES 7
@trevorBraun  sometimes, an os update of setting change on your phone can cause it too.
I know shouldn't be disappear but good part is all back to working condition now
Maybe network setting got reset some how
** I am not a Mod, please do not include any private info in a private message to me.**
trevorBraun
thanks that worked when I inputted all of those settings, Why would they have disappeared? and stopped working?
Samianauman
Here's a Xperia 3 apn location link
https://www.spark.co.nz/help/mobile-data/device/sony/xperia-z/check-apn-settings-sony-xperia-z/
And here's the public mobile apn setting
Once you double check your phone is unlocked here's a link where you can get all apn setting click on the link to get details
 http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Setting-Up-Data-On-Your-Phone/ta-p/26
trevorBraun
Ifound APN and its Public Mobile
trevorBraun
what where do I find APN? I see Internet Settings and I click that- it says it will connect to internet and nothing happens.  It was working fine a few days agoa
will13am
Have you checked the APN settings to make sure they are correct?  Checked that mobile data is enabled and that the data meter is set above the current usage value.
