Need PUK code please
05-10-2017 12:47 PM - edited 01-04-2022 01:46 PM
Phones
11-11-2017 08:25 AM
Need puk code k never set one so sim just came with ghe dim card
05-10-2017 02:23 PM
This is what I found looking through this forum for PUK code. Looks like a private message to a moderator may help resolve things.
05-10-2017 01:26 PM
@ashley2017 wrote:
Thanks for the reply
I have been using a telus locked phone with public service.. I am now going bell and they are saying PUK code needs to come from here.
Phone is locked to telus phone need to be unlocked to work on bell network
05-10-2017 01:23 PM
@ashley2017 do you remember the PIN code you set for Telus/Public Mobile when you first signed up?
05-10-2017 01:23 PM
05-10-2017 01:19 PM
05-10-2017 01:07 PM
PUK Code. PIN UnlocK code / PIN Unlock Key. PUK is the code required to unlock a GSM SIM card that has disabled itself after an incorrect PIN code was entered 3-5 times in a row. ... If an incorrect PUK code is entered a certain number of times (typically 5-10), the SIM card will permanently block (disable) itself.
05-10-2017 01:04 PM
I think you will have to contact Telus...
Here is info for you: https://en.wikipedia.org/wiki/Personal_unblocking_code
FYI, unlocking with the PUK code is not the same than what is commonly understood by "unlocking a phone" to allow it to work on other carrier.
05-10-2017 12:57 PM - edited 05-10-2017 12:59 PM
If you bought it third party then its more likely lock to some other carrier and that's why it's asking for puk
05-10-2017 12:53 PM
if its locked to telus, the phone should still work with public mobile!
05-10-2017 12:49 PM - edited 05-10-2017 12:51 PM
Who are you using to unlock the phone? What kind of phone is it?
You will need to use a service than can provide you with the unlokcing service.
Just to add, this is a service you will have to pay for. Android phones are much easier to get this done than iphones.
