09-11-2025
08:07 PM
09-11-2025
11:09 PM
computergeek541
09-11-2025 08:28 PM - edited 09-11-2025 08:29 PM
@Farazali100 wrote:How do I message them? They send a code on the phone number which I never had access
message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
(Just want to clarify, you won't get any issue for tagging CS_agent, they just won't reply post here even you tagged them)
09-11-2025 08:27 PM
Ok I will wait Thanks for your kind help
09-11-2025 08:25 PM
09-11-2025 08:22 PM
@Farazali100 tagging CS_agent here won't help
you need to message them and open a ticket.
09-11-2025 08:21 PM
No it is not as it is showing my account still active @CS_Agent
09-11-2025 08:17 PM - edited 09-11-2025 08:18 PM
@Farazali100 wrote:I chated with Cs_agent and he assured me that my account is closed and refund on its way. I don't have access to the phone never did as I can't download load the app on my phone due to different country settings in play store
hi @Farazali100
then issue is resolved?
if account is closed, it is normal that you won't be able to login again. So, for now, just wait for the refund, which could take 2 to 3 weeks
if you need CS agent still, just message them
09-11-2025 08:15 PM
09-11-2025 08:10 PM
did you cancel it properly? you can either port out the number or you login My Account -> Profile-> Manage EverSafe ID and turn off Subscribed
if you need PM to check, you need to open ticket.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
