check requirements
roymcsheffrey
I am looking at getting your $50/8GB plan. This is for my cottage and I need to know what band it uses for 3G data and what speed will it be. I currently need a cell booster (Bands 5 and 17) for present operation. Also what LTE bands does it support. My postal code is j0x2j0. Tks Roy
7 REPLIES 7
roymcsheffrey
I'm currently only getting about 2.5mbps  now with bell high (slow) speed internet, and its costing me $65 a month.  I figure I can whittle down my usage enough to get by on 8 GB of data.  Thank you very much for your info.  Roy
zero_gravity
@roymcsheffrey wrote:
Thanks for the info. Now does anyone know the approx. download speed that can be achieved using 3G, I know this is dependant on the signal strenght, but assuming -110 dbm's, that's about all I can get with my booster. Tks Roy
I find I get around 3 mbit give or take. Plenty for web browsing, etc. It's tasks such as streaming that I'd want faster.
jor123
@zero_gravity wrote:
FYI when you pick a 3G plan, you will still connect to the LTE network if available just as if you had purchased LTE data. Your network speed is simply throttled to the speed of 3G.
This confused me as well when I recently switched to 3G speed. PMs site does not explain this well.
Thankfully as the LTE latency is much better than HSPA!
roymcsheffrey
zero_gravity
Did you check the compatibility checker under Get Started above? If not listed let us know the make/model/submodel and someone here can figure things out for you.
geopublic
@roymcsheffrey  For 3G PM uses band 2 and band 5. For LTE PM uses Bands, 2, 4, 5,7,12,13,17 and 29.
PM uses Telus and Bell towers so best to check the map here
