changing address - Invalid / missing City
dcpipal
I have 2 accounts/phone numbe that need an address update. Unfortunately when I change the address the city is invalid and not listed on the pull down menu.
1 REPLY 1
@dcpipal   Yes, the city list provided is no where close to full city list for Canada.
But you can simply pick a city closest to you.   The address info, city is not important, it is NOT to be used for Credit card validation or other important thing.   It is simply a record keeping for Public Mobile. So, there is no problem you just pick one closest to you instead
