07-09-2025
09:43 PM
07-10-2025
12:23 AM
computergeek541
how can I change my subscription to 1gb which is cost 19.99 cad i couldnt see it in the app but my husband use it in his phone
07-09-2025 09:45 PM
you can only change to plans that are available when you log in to your account as not all customers can get same plans. If you have a more costly plan that $19, chances are you can't downgrade...only upgrade.
07-09-2025 09:44 PM
if you don't see it on the Change Subscription on your My Account, then the plan is not offered for you , you really cannot change to it. Sorry
