12-31-2023
08:01 PM
01-03-2024
01:38 PM
Dunkman
I changed my phone number, from """""""" 211 to """"""""" 898,
but the confirmation code is still going to the previous number.
This is the second time I am sending you a message, I hope you will take care of it soon
please fix it
thanks
01-02-2024 03:40 PM
Echoing what softech stated earlier.
Otherwise you can also see if giving the system some time to update fixes the issues. I find with PM there is often a lag or delay.
01-01-2024 02:52 AM
thank you very much❤️
12-31-2023 09:40 PM - edited 12-31-2023 09:42 PM
@Jubin yes, this seems to be a. system problem
But you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Didn't get the code? or Resend code and then choose Send email
After you able to log back in, go to Profile page, click Manage EverSafe ID and then you can update the phone number there
https://myaccount.publicmobile.ca/en/account/my-profile
12-31-2023 08:14 PM
hello do you want to say that your cell number has not been changed?
