cellular data
10-14-2019 07:07 PM - edited 01-05-2022 07:34 AM
Newer member
I have an apple i4 phone but cant get the cellular data to work
Joining Public
10-14-2019 09:42 PM
@Master2001Your statement is not applicable in this case, because the OP had indicated he gets voice service.
10-14-2019 09:37 PM
Try connecting your iPhone to your computer with a USB cable and run iTunes. IPhone devices may need to connect to an Apple server to activate.
10-14-2019 09:25 PM - edited 10-14-2019 09:27 PM
@Domsil14I would recommend swapping your SIM card into another phone to verify that data is indeed working.
Once you have verified.. then go to http://www.unlockit.co.nz/unlockit/ and create an APN profile for your phone.
Do note MMS won't work for your phone.
10-14-2019 08:24 PM
I am able to get text messages and calls and Internet at home off my home internet just no data away from home
10-14-2019 08:14 PM
It is an A1332
10-14-2019 08:02 PM
@will13am wrote:I put a Public Mobile SIM into a freshly factory resetted iPhone 4s and I did not need to do anything to have the full service working. I wonder if a simple network reset may do it.
Anything after iPhone 4s and iPhone 4s is fine with PM for Data but anything before that you can not manually or Auto input APN settings, so the only option is to follow the other person instructions. Go to unlockit.nz or something like that with WiFi on and use safari to install what is called an APN profile. FYI. With this option Remember you will get data and iMessage working but Regular MMS messaging won't work because again you are unable to add or edit the MMS APN settings.
10-14-2019 07:53 PM
@Domsil14There are a few variants of iPhone 4? What is the exact model number? If it is not A1332, your phone is not compatible with any networks in Canada.
10-14-2019 07:48 PM
it says to put in sp.mb.com under APN. I did that still no cellular
10-14-2019 07:29 PM
10-14-2019 07:11 PM
@Domsil14 wrote:Newer member
Early iPhone APN settings cannot be updated manually. You will need to connect to wifi, access http://www.unlockit.co.nz/mobilesettings/ with Safari, then follow the directions there. pasted from @Luddite's quirks thread
