cannot process payment
jimmy45
@CS_Agent I am using a visa debit which I have recently had activated. I am getting the message that my card information cannot be verified when I try to make a payment. I have been to the bank to insure the card is working properly and have triple checked all fields to be sure info is entered correctly. Please help as I have been without service for over a week now trying to fix this issue
1 REPLY 1
SD08
When the billing system rejects your card, sometimes trying the following works:
-clear your browser cookies/cache
-use a different browser
-use private/incognito browsing mode
-turn off ad/pop-up blockers
-use a different device (tablet, desktop, laptop)
Note:  When attempting payment, check your card account after each attempt to avoid being double charged.
If none of these work for you, then you should send a private message to the Moderator Team for help.
If you've made multiple attempts, the mods can check to see if there is any block against your card on PM's end from having made too many attempts in a short period.
