cancelation
Vitaly1
how to make a cancelation contract
2 REPLIES 2
Vitaly1
thanks
slusagm
no contract here, you can just disable Autopay so PM won't charge you again and effectively cancelling the subscription
Login to My Account -> Payment -> Manage Subscription and disable "Subscripted"
(or if you are using the App, go to Subscription -> Manage subscription and click Unsubscribed"
if you cannot login My Account, then ask PM to help to remove the credit card from your account.  Message them here:
