judepark
I happily joined couple days ago but could not make it. It was impossible to transfer my own number so could you cancel my order and return please. Thanks
1 REPLY 1
hi @judepark
what was the transfer issue?
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
