05-08-2018 09:13 PM - edited 01-04-2022 04:14 PM
trying to setup a new line, but couldn't login to account...try to reset password, but got the following error: ForgotPassword/LoginUnsuccessfulUser_LoginDisabled
then try to send private message to admin, but apparently i reached the private message limit without sending a single private message...
05-09-2018 09:25 AM
Hey @kevin777,
thank you for reaching out to us !
Oh no ! I'm really sorry to hear that you haven't been able to log onto your self-serve or seek help. As other users mentioned, the bug should disappear on it's own - can you please try sending us a private message now ?
Thank you 🙂
Mary
05-09-2018 08:50 AM - edited 05-09-2018 10:08 AM
The limit on private message bug goes away on its own sometimes. I have found that messages with attachments can easily bring up this problem. Logout and login cycle sometimes clears it. Try using a different browser.
05-08-2018 09:19 PM
a) Look in your sent message folder; sometimes mine have gone through in spite of the message.
b) Logout of Community, then log back. Usually works for me.
