can't send SMS
David33B
How do I know what the SMSC number should be?
Roman_ua
Roman_ua
Just transferred from Bell.
And my SMS doesn't work.
@David33B I don't think you can change it update it.
SMSC: 16475800172
if you have trouble sending SMS, start with Reset All Networks
or update the APN instead
Sansan
@David33B  new customers were having sms issues, but that should be all fixed now per public mobile. After one hour your messages should work. Power off your phone and see what happens.
If still unable yo send or receive sms use the chatbot to create a ticket.
What is are you calling SMSC?
