can I add the refer number after I register? need help please!
henryzpb
forget to enter refer number when register what should I do?
srlawren
 Hi @henryzpb, welcome to Public Mobile!  We hope you love it here as much as we do 🙂
As mentioned, there isn't a way for you to do this yourself, but as @NDesai indicated, please send @Mary_M a prviate message with your phone number, and the phone number of the person that referred you, and she should be able to take care of it for you.  Please do NOT post either phone numbers in this thread though--community postings are visible to anyone, including Google search engine.  Please only send those numbers via Private Message.  If you're not sure how, please see these instructions:  http://productioncommunity.publicmobile.ca/t5/Getting-Started/Private-Messages-viewing-and-creating/...
Welcome aboard!
Pier
Hi Henry,
I don't think there is a way to do that as the process has done already. If you didn't add any # as reference during the activation time, it's like you miss the train; you won't be able to do it after. Now, let hunt for new subscribers that can give your number as reference.
Good luck,
NDesai
You won't be able to, but Public Mobile staff member probably can.
@Shazia_K @Mary_M
