call forwarding not working
nourel
Trying to forward my busy, unavailable calls to another number. Was working up until recently, no longer forwarding calls now. I tried the codes in https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding but it is still not working.
1 REPLY 1
LitlLdy
@nourel , call forwarding has been messed up for a lot of us. I had to contact CSA to fix it on their end so I can use it again! Please send a supporting ticket & ask them to fix it on your account.
  • Get help with your service or account by starting a conversation with the virtual assistant, SIMon. It can help you submit a ticket to the Customer Support Agents. Click here to get started and type Customer Support Agent, then select Contact Us, then select the topic that matches your request.
  • Alternatively, you can send a private message to Customer Support Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
