billing
Smita
my account is frozen and i need to make my payment
>I have a pre registered credit card!!!
@Smita  then you can login my account and make a manual payment by clicking Reactivate my plan.  Or you can use *611 to make a payment with credit card on the system if you know the 4 digits PIN
@Smita do you have access to My Account?
or you can get vouchers from SDM/711/London drugs/Shell (best to get from there as vochers from there can be used immediately).  and then load vouchers via *611.
Smita
dust2dust
Do you know your 4 digit account pin? You can dial 611 and use the registered credit card. You can also buy vouchers in lots of stores or online and use 611 to enter it. No pin needed for that option. Or you can use the real time payments method in some stores.
