10-24-2022 04:02 PM
10-24-2022 04:40 PM
You can also dial 1-855-4pu-blic from another phone and enter your phone number and then using your 4 digit account pin, toggle off autopay.
So if you want to close it I guess you wouldn't want to buy a sim.
10-24-2022 04:22 PM
No, the account is not closed. I want to close it. I have not been able to sign in to the website. When I ask for password reset I don't receive the code that they send??? I do not have the sim card. Left it at T-Mobile. Grrrrr
10-24-2022 04:15 PM - edited 10-24-2022 04:16 PM
10-24-2022 04:13 PM
@KMC1 Removing the SIM card won't stop payments and you need to put the SIM card back in your phone if you want to access 611 menu.
Contact support to remove any payment card from your account as advised already.
10-24-2022 04:10 PM
I have already removed the Public Mobile sim card so *611 is unavailable
10-24-2022 04:07 PM - edited 10-24-2022 04:07 PM
@KMC1 hi you can cancel autopay in your self serve account or by dialling *611 on your phone if you have your pin number also you can
contact a customer service agent to remove your cc from your account
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-24-2022 04:07 PM
If you know your 4 digit account pin then you can toggle it off via 611.
10-24-2022 04:05 PM
@KMC1 wrote:how doI cancel autopay when I have no access to the app or online?
Public Mobile doesn't have a Self Serve app. You will need to regain access to your Self Serve account to disabled pre-authorized payments. Are you have a password issue?
