auto pay rewards
tamaraxo12
ive had public mobile for over a year and my plan is $30 a month with $2 off with auto pay and i pay $32.75 a month and was paying 28.75....any idea as to why ?
8 REPLIES 8
@tamaraxo12
If you listed your account/phone number into Lost/Stolen at any point, this could affect your rewards being given to you.
If this is the case, contact CSA to have them apply your rewards for you.
Methods to contact CSA: https://www.publicmobile.ca/en/ns/get-help/articles/contact-a-moderator
BUT, if this is not the case, a picture is worth a 1000 words here. Can you post your payment history details, blocking out personal info. of course.
dabr
@tamaraxo12    Your numbers are confusing as mentioned already.  Are they correct or is there a typo in your post?
BTW did you have any referral rewards in addition to your autopay?  Perhaps you've lost one/more referrals either through suspension or they've left PM...
28.75 is 25 at 15%
Not a clue how 32.75 is derived.
Please post screenshots of your payment history from here. Blank out personal info of course.
LeePublic
@tamaraxo12 Are you on a older $30 2 GB plan? It appears you may have a auto pay failure or the auto pay discount may not have been applied correctly, thus why the amount is higher this month.
will13am
Nothing seems to add up here.  With autopay, the base plan cost should be $28 per month.  If the after tax charge was $32.75, the implied tax rate is about 17%.  I don't know of any province or territory that has a 17% total tax rate.
@tamaraxo12   which province you are at?  I was trying to work out the pre-tax amount, both $32.75 and $28.75 do not work out ...
t_p
@tamaraxo12
Do you mean you're paying 28.75 since opening your account and just this month that switches to 32.75?
If the only reward in your account is from Autopay, the 32.75 looks correct (inc. taxes) and the 28.75 looks iffy to me? Maybe an error from PM accounting?
You can contact CS but let's hope if it's their error, they won't charge you for the missing $$!
@tamaraxo12   can you logon to My Account and confirm if your Autopay reward is showing under My Rewards?
Also, check the Transaction History for this month and see how PM charged you and see if you see a line like this:
Worst case, you might want to open a ticket with PM using Chatbot.  Follow this to get to ticket open screen quicker:
  1. Type: My rewards are missing
  2. click  AutoPay reward
  3. Then click "Contact Us" , and then click "Click here to submit a ticket"
  4. you will then direct to another page to open ticket.
