add text into plan
Nav
i have 135 plan per months months can i get text plan in that
JaK
Good stuff, thanks for the update @Shazia_K!
Shazia_K
Retraité / Retired
Retraité / Retired
@srlawren@NDesai
The issue was resolved yesterday.
Thanks 🙂
Shazia
JaK
It's happened a fair bit, seen serveral of these aready...
@Nav, when did you active your plan? If it was very recent, the moderators are often able to just add it for you. @Shazia_K@Mary_M
srlawren
@Luddite sounds like it eh?  Ironically, due to the increased pick-and-pay discount, the 90-day, canada-wide talk, and 6GB of data is the smae price ($135) with or without texting.
Do you mean you just picked 90 days Canada wide calling and 6 GB data for $135, and now wonder if you may add texting?
NDesai
Not sure what plan you're talking about.
Did you select Text when activating?
