02-18-2023 12:55 AM
I received 2GB of data and 500 mins add-on usage during the PM promotion. Will these bonuses be expired if I do not use them? If I want to use the bonuses, what should I do?
02-18-2023 12:57 AM
They will not expire. The data will only get used when you run out of plan data. If you are on the $15 plan then those minutes will get used over the 100 minutes outgoing. Or otherwise if you call the states or a handful of other countries.
