activation
idlhands
when activating a SIM card do i actually have to make the first payment with a visa debit or credit card? i bough a payment voucher and it wont seem to let me use that to activate the SIM for the first time.
@idlhands
You can purchase a reloadable Visa card from any gas station or supermarket like these to activate the SIM:
@computergeek541 wrote:
@esjliv wrote:
@idlhands - the activation pages do not currently allow a SIM card to be activated and an account created by voucher. So as stated above contact Customer Support and tell them you want to create a My Account and activate the SIM card you obtained. They have made these exceptions in the past according to other posts, so they should be able to help you out as well.
The information that I have seen indicates that isn't an exception, but rather a set procedure to be followed in the cases of the customer not having a credit or debit card that can be used during activation.
That that is good @computergeek541 .
It is difficult to post something with certainty for this particular situation as I am not sure where I can find something stated from PM about this. So, suggesting to contact CSA for help and see if they can set them up is my current comfort level of advice. 🙂
HALIMACS
@idlhands
Activation is much easier with a credit card or Visa or MasterCard debit.
In order to use payment vouchers, you require support from customer assistance.
  1. Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request).  Click the result which states Click here to submit a ticket and follow the prompts,  or,
  2. Send a private message to the Customer Support Agent by clicking here  You’ll need to be logged into your Community account for the link to work.
