account
Kim69
account keeps locking me out?  What do i do?
Thank you
kim
cavemantoronto
Thank you
kim
This happens if you type in password wrong a few times. If you know password is right, could be typing it wrong.  Wait 1 hour and try again.
sandpublic
Thank you
kim
Make sure you're using the correct email (The one you signed up with on the account).
Lieux
Thank you
kim
Did you try the button FORGET MY PASSWORD? If yes you need to write a message to the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain what happened. The waiting time is few hours to 2 days.
