07-03-2019 04:41 AM - edited 01-05-2022 05:42 AM
07-03-2019 09:43 PM - edited 07-03-2019 09:49 PM
@annabean wrote:activated new sim want old public mobile number
@annabean, in one message to me, you said that you only wanted to attach a new sim card to your existing Public Mobile account. Yet, in another message, you said to me that you wanted to changed your phone number. In this message thread, I am reading discussion about number porting. Can you clarify what you're trying to get done? Thanks.
07-03-2019 09:32 PM
Annabean, I have moved all your message posts into one message thread so that others can try to help figure this out for you.
07-03-2019 09:28 PM
Did you already get a new number from public mobile? If you haven't you can do that during setup. If you have I don't belive you can change it easily.
07-03-2019 09:27 PM
07-03-2019 09:22 PM - edited 07-03-2019 09:23 PM
@annabean Hi I don't believe thats possible someone else probably has it by now when did you have that old number?
07-03-2019 09:19 PM
07-03-2019 09:16 PM
change number to old public number
07-03-2019 09:06 PM
@annabeanIf you just want to change SIM it is also easy just to go your selfserve and type in your new Public Mobile SIM card.
07-03-2019 08:34 PM
change sim not number
07-03-2019 02:24 PM
@Anonymous wrote:
@annabean wrote:haviing trouble activating my sim with old number
Maybe @stonechucker could move this up to the main forum area.
@annabean: Which step of the process are you having problems at? Which provider are you trying to transfer from?
Post moved to increase visibility.
07-03-2019 02:10 PM - edited 07-03-2019 02:25 PM
07-03-2019 10:53 AM
ok, but I just had trouble with porting from TELUS and that's the first thing the call center agent checked. It was not the case for me but I assumed it was an issue for some. Perhaps they were making sure my account was in good standing and not that there was a few bucks that needed to be settled up.
07-03-2019 10:47 AM
Hi there, please make sure you're using SIM activation page found here: https://activate.publicmobile.ca/
You should be prompted after punching in the SIM card #.
07-03-2019 10:21 AM
Prepaid accounts require funds to be loaded at time of activation
@annabean wrote:having trouble with activation with sim using old number but it says need to make payment first
07-03-2019 10:20 AM - edited 07-03-2019 10:22 AM
Usually balance does not prevent port unless it is a delinquent account
They* send you final bill after you port out
*edit for clarity - They means OTHER carriers, Public is prepay so not possible to have an outstanding balance due
07-03-2019 09:42 AM
Just an observation, is it possible there's an outstanding balance on your old account? Because you can't port your number if you have a balance on your old account. Might that be what the error is saying?
07-03-2019 08:06 AM - edited 07-03-2019 08:07 AM
Are your trying to Transfer (port) a phone# from another provider ?
Here is more info about porting.
https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
07-03-2019 07:38 AM
@annabean what exact issues are you having? PMis a prepaid service so it will ask for funds up front.
allso don'tforget to use a friends number as a referal to get a 10$ post activation credit.
07-03-2019 04:54 AM - edited 07-03-2019 04:55 AM
@annabeanAre you trying to activate a SIM card and keep your old number ie porting? If so it is advisable to activate your SIM with a temporary number.. then port the number after everything is working. That way you will be able to call / text out and have data while the porting process is going on. Do note, during the process your old account with your other provider has to be active.
07-03-2019 04:51 AM
