02-14-2018 10:56 AM - edited 01-04-2022 03:31 PM
my zenfone 4 is not getting data. I just did a set up on this new phone and get wifi, cellular connection but no data ?
02-14-2018 12:38 PM
Yuppers, like the others said check that APN.
Have experience now with three Zenfones (including a Zenfone 4 Max) and all had incorrect auto-added APNs (were for Telus and Koodo). Once I manually added a PM APN (see @will13am's post) data worked. I think I had to reboot too after adding.
Good luck!
02-14-2018 12:01 PM
Clarify please: are you able to make/recieve calls and send/receive texts but it's data that is not working?
If yes, then definitely it's just the APN settigs. I had to manually set that up too on my Sony Xperia which I'm guessing is running the same OS as you. Something about not having the correct carrier settings for Public Mobile in the back-end Database for Carrier codes.
02-14-2018 11:03 AM - edited 02-14-2018 11:04 AM
@deryckhart, the likely problem is the APN settings need to be properly set on your phone. Use the following link as a guide. Once the APN is set up, make sure that mobile data is enabled.
@https://apn-canada.gishan.net/net_15_public_mobile_internet_and_mms_settings.php
