ZTE Fanfare 3 supported?
slugbug55
I have a ZTE Fanfare 3 Z852 and was wondering if it is supported. I see ZTE Fanfare in the list but no Fanfare 3.
@jimdheil apparently it has the correct 3g frequencies, so it should work.
3G bandsHSDPA 850 / 900 / 1900 / 2100
SpeedHSPA 7.2/5.76 Mbps
jimdheil
Nice I have a ZTE Firefox OS phone. I never even thought to check if I could use it with mobile as I only bought it to develop Firefox apps. Then the operating system was discontinued. I'd be interested to know if I could use this phone on the nextwork. It might be worth getting a 2nd SIM if possible.
tabi159w
It should work with PM fine. The compatibility checker is outdated.
gpixel
@slugbug55 hi yes it should work with pm
8GB Sorage (5.2GB User) 1GB RAM / GSM: 850/1900MHz - UMTS: 850/1900MHz - LTE: B2/B4/B5/B12
