Wrong data usage
stephyannjose
I haven't used my data yet, but showing in my usage as 966 MB used out of 1024 MB within two days of renewal
DOA
Check your phone to discover which (if any) apps are sucking your data.
If you don't know how, just google "check app data usage ios or android."
Triguy
Make you turn off auto updates and GPS.
You can view your usage in your self serve account.
https://www.publicmobile.ca/en/on/get-help/articles/managing-your-data-usage
@stephyannjose if you do find that that you are out of data. You can look into buying the $15 1 gig data addon. Here's an article on buying add ons. https://www.publicmobile.ca/en/on/get-help/articles/purchase-add-ons-through-self-serve . Its a 2 step process add the funds and then buy it.  See below on where to do it. 20200417_204130.jpg
darlicious
@stephyannjose
Do you take screenshots before and after renewal? It sounds like your data did not reset after renewal. Do you know how you used last month? Have you reset your data tracker in your phone? What does it show for your previous 30 days?
Contact the moderators as suggested by @gblackma  and if it's a case of it not resetting the moderators can easily do that. You can also look at your daily usage history and add up the twice daily web usage updates since renewal to see if they match what they claim is used....that will help you determine if it reset properly at renewal.
gblackma
@stephyannjose they are normally pretty good at monitering your usage.  Check your usage history for the last 2 days in your self service account  and your app usage on your phone to see who the major culprits are. If you still feel that an error occurred, then contact the moderators and ask them to to look into it for you.   There are 2 ways to contact the Moderator Team:
  • Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password.  Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen.  The mods answer will show up there.  When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue.Stay safe.
Welcome to PM .
