Wrong charge
jpniyitanga
Hello,
I ported my number out and I am still being charged.
2 REPLIES 2
@jpniyitanga   if you confirmed that you did port out successfully (the incoming calls going to your new provider) , then you can direct message PM Support for a refund and get it stopped
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
@jpniyitanga wrote:
Hello,
Can you check to see if your Public Mobile service still works? If it does still work, the port out didn't complete.
