11-23-2016 12:43 PM - edited 01-05-2022 12:51 AM
11-23-2016 12:48 PM
As mentioned above, coverage map would show where service is available.
If you want to check a bit more, check whether there is anyone using Telus. If there is, you know you can get service through PM as well. 🙂
11-23-2016 12:45 PM
The coverage map shows coverage there so I don't see why not.
