11-02-2019 01:44 AM - edited 01-05-2022 09:37 AM
Have user name.....PM says it is email. Holy Smokes Bat Man...I know my email.
For password, well Robin, I know that too.....and nothing.
Just want to get my credit card re-registered for the expiry date.....but can't even get in.
11-02-2019 10:09 AM
The previous member's response should resolve your issue.
11-02-2019 03:17 AM - edited 11-02-2019 03:21 AM
@@000000086 Once you sort out getting your password and updating your credit card take the time to write down your password, pin #, security question and answer and put it in a safe place. That way if this happens again you can refer to it. There have been many posts from users go do not access their accounts very often a simply forget what was so obvious to them hen they created it.
Please change your user name if that is your phone # keep it private on the forum or getting spam calls will be the least f your worries...
11-02-2019 01:51 AM - edited 11-02-2019 01:53 AM
@7782694286 wrote:Have user name.....PM says it is email. Holy Smokes Bat Man...I know my email.
Please try again after 1 hour.
It may also help if you clear your browser cache and open a tab using incognito mode.
Reset Your Self-Serve Password
If you forget your password, there’s no need to worry. You can create a new one by following these simple steps:
You will receive an email outlining how to change your password. If you don’t get this email within 30 minutes, please start a conversation with our virtual assistant, SIMon by clicking here, to submit a ticket to the Moderator Team.
