02-04-2020 07:46 PM - edited 01-05-2022 09:21 AM
On the page to check if your phone is available, I select LG, but there is no G7 option. There is only a G7 Fit option or G8 ThinQ. Does this mean the LG G7 ThinQ isn't compatible with Public Mobile?
02-05-2020 01:58 AM
@JohnoRono wrote:On the page to check if your phone is available, I select LG, but there is no G7 option. There is only a G7 Fit option or G8 ThinQ. Does this mean the LG G7 ThinQ isn't compatible with Public Mobile?
The compatibility list will never be complete. It's far more important to know what you have/what phone you are going to get and which frequencies and technologies that it supports.
3g network suppport on bands 5 and 2 (850 and 1900MHz) are a must because you won't be able to make or receieve any phone calls without them.
02-04-2020 08:13 PM
I have an old LG G3 & Public Mobile works fine on it so I would think for sure a newer model would be no problem.
02-04-2020 07:57 PM
You are welcome @JohnoRono Thanks for choosing my response as the solution . Have a great week.
@JohnoRono wrote:Thanks!
02-04-2020 07:56 PM
Thanks!
02-04-2020 07:54 PM - edited 02-04-2020 07:55 PM
@JohnoRono the g7 thin is sold by Koodo which isalso owned by Telus . So yes it is. Welcome to PM. https://www.koodomobile.com/phones/lg-g7-thinq
