07-09-2020 05:50 PM - edited 01-05-2022 12:24 PM
I am your client for 2 years. I had $1 off my plan (loyalty). Suddenly it disappeared.
May I ask PM, what is going on?
07-16-2020 12:45 PM
@telemonster .... which reward are you referring to? If its the reward for staying a complete year, I believe it only getts applied after 13 month, then every 12 month after that for a total of 5 years or up to maximum of $5.00 off per month. if you stay 5years and 1 month or more time with PM.
07-09-2020 05:56 PM
07-09-2020 05:53 PM
@telemonster contact the moderators and ask them to look into it for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
07-09-2020 05:51 PM - edited 07-09-2020 06:03 PM
@telemonsteryou should contact moderators. I would tell you how, but I'm sure you already know
maybe pm is doing a cleanup on false loyalty rewards 🤭
