Where do I see my remaining data?
Alexo
The "Data and add-on usage" page only shows me the boosters, not the plan data.
Suggestions?
Alexo
Tangentially, I do not believe that the word "dаmn" is bleep-worthy.  Aren't we going a bit overboard with the filtering?
Edit:
And now it has been removed from my post by a moderator.  Lovely.
Alexo
I had a whole day Internet outage yesterday and tethered my phone in order to be able to work.  Apparently Windows 10 does not treat USB connections as metered and decided to siphon 2.2GB by "background transfers" very quickly.
This is the equivalent of $75 down the drain.
Lesson learned, all networks set to metered by default.
https://www.tenforums.com/tutorials/35656-set-ethernet-connection-metered-unmetered-windows-10-a.htm...
RossN
@Alexo Hi it shows up on your main page your overview page in your self serve down the bottom if you do not see any data it is all used up for this cycle Under data and add-ons
Triguy
It should be under data and add-ons.  If no data is showing then it means you have used up your data.
gblackma
@Alexo If your plan data isn't showing its used up. It should look like my plan below.
