When does PM support esim?
laofei
Telus and Koodo already support esim. Why PM still didn't support esim?
srlawren
@laofei  When?:  Eventually™.
EDIT: my best guess: when there are enough popular devices that only offer eSIM and no physical SIM slot to make it pretty much a do-or-close-your-doors type of prospect.
kselmak
@laofei
Community members cannot answer this question, only decision makers can. We can  only offer guesses opinions suspicions and wishes
geopublic
@laofei  Most PM customers currently don't require eSIM support, so my guess is that it won't be for quite awhile. Most mid range phones support 2 SIMS anyway so eSIM is not a requirement. eSIM is usually promoted/pushed/available on higher end phone manufactures like Apple, Pixel 4 etc for the same reason batteries, headphone jacks were eliminated in the past, control and allowing them to "milk" the end user for more $.
If eSIM is a must for you then you need to look at the providers that currently support it.
gjong26
According to the link below there are carriers that support esim.  Its dated Sep 2019 mind you.
https://mobilesyrup.com/2019/09/06/canadian-carriers-support-esim-technology/
Jb456
Uncertain. They're likely evaluating the option and the competitive environment with other 3 tier providers. No one knows if it will be offered.
ShawnC13
Because PM is the third tier provider of Telus.  It is up to them when PM will support e-sims
