08-20-2019 04:08 PM - edited 01-05-2022 08:37 AM
08-20-2019 05:53 PM
@dezmon71 wrote:I had posted a question, but it never showed up. This was a follow up to find out what happened.
@dezmon71 it's definitely there: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/Why-was-my-CC-charged-twice/m...
08-20-2019 04:42 PM
08-20-2019 04:25 PM
@dezmon71 I see it it says What happened to my question? lol![]()
08-20-2019 04:24 PM - edited 08-20-2019 04:24 PM
To find your post, go to your profile page. You will see your posts listed there if it was not deleted by someone.
08-20-2019 04:13 PM
This happened to me before. I found this 'folder' called "My Rejected Items" and found my post there. Are you able to locate your post in some sort of 'rejected' place?
08-20-2019 04:12 PM
Try again ![]()
08-20-2019 04:11 PM
@dezmon71 There's a chance it got moved to a more appropriate subject area by one of the Oracles. It doesn't show up if you do a search?
If you go to MyProfile, you should see your latest posts there.
