[Website bug] Link device compatibility checker script as HTTPS
rexbron
Similar to the number porting regex, the first page of your activation website loads insecure content that Chrome blocks. The URL in question is:
http://mobility.telus.com/devicecompatibilitycheck/?locale=en
As the link redirects to HTTPS when you load it, it should be a simple matter of changing the protocol in the link.
This needs to be served over https to be loaded as per https://support.google.com/chrome/answer/1342714?p=unauthenticated&visit_id=1-636340439403718941-415...
2 REPLIES 2
rexbron
Yeah, it drove me nuts when I was trying to activate. Only on the fifth or sixth attempt did I try it in incognito mode and noticed the icon.
Safari also has the same behavior of blocking non-https sources on https sites.
will13am
This may be the smoking gun for why Chrome browser has been reported as failing when used for activation.
