Vouchers
ladybug10
  • What's the number I call to pay my bill. I was locked out. 611 is not working?
2 REPLIES 2
Yummy
You could apply voucher through your account (use computer, not phone).
@ladybug10   you cannot use *611?
try to call 1.855.4PUBLIC, then enter 1 for English and then enter your phone number, it works just like *611
Also, you tried to login to My Account?  You can load voucher there as well
If you forgot the password, try to self reset it there using the Reset Password link
if it does not work, open ticket with PM support and they can help to reset the My Account password
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
