11-03-2016 07:29 PM - edited 01-04-2022 04:15 PM
If you purchase a voucher, do you have to wait a while before its active??? Theres a PIN# and a Ref#... if I enter either when trying to add it to my account I just get this... "Unfortunately, Voucher could not be added. Please verify the Voucher and try again."
02-15-2017 03:24 PM
There are still advantages buying vouchers (while keeping the autopay) if you have discounted giftcards/gas cards, reward points, or even credit card that gives more rebate at gas stations. Or you can stock up on vouchers from province that charges less sales tax (or ask a friend to buy them for you).
02-15-2017 03:12 PM
@warpdrive that's a great tip!
I started on a voucher, and it caused me problems when I attempted to register for payment on my plan. Now I know to use *611. Thanks!
02-15-2017 02:34 PM
02-15-2017 02:22 PM
i bought 3 vouchers last night and loaded all 3 codes on the selfserve site at the same time. There was no wait and I received sms confirmation right away.
11-04-2016 12:46 PM
No problem!
11-04-2016 12:33 PM
the phone method worked for me. Thank you
11-04-2016 08:53 AM
It was suggested to me to dial *611 and add the voucher through the automated phone system. This worked for me.
11-04-2016 03:16 AM - edited 11-04-2016 03:18 AM
Same with me and I don't get it. Doesn't work. Never does. I try all the numbers dozens of times. There are 12 numbers as the voucher # and I don't use any spaces and still it does not work. What am I doing wrong?
Mary_M said
That is because I manually adjusted the account, rest assured that everything will be renewed smoothly. So if Mary manually ajusted the account, why does it still not work? I think many people have the same issue.
