Voicemail
06-28-2021 03:03 PM - edited 01-06-2022 02:38 AM
I cannot reset my voicemail password after migrating house number to cell and therefore can't retrieve my messages.I tried doung self serve but itcsays this number cannot be changed or it doesnt recognize data.
Joining Public
06-28-2021 03:59 PM - edited 06-28-2021 04:00 PM
@Garlandgrace wrote:I cannot reset my voicemail password after migrating house number to cell and therefore can't retrieve my messages.I tried doing self serve but it says this number cannot be changed or it doesn't recognize data.
Since you mention migrating your house number - if this was very recent, it can sometimes take upwards of a week or two to fully complete a port of a land-line number. Can you confirm if incoming calls from other carriers are arriving at your Public Mobile phone? If you can confirm you are able to receive calls on Public Mobile using your previous phone number, then proceed with the next step. If not, you likely have to wait a bit longer for the porting process to complete.
To reset your Public Mobile voicemail password, login to the self serve portal, and choose the "Reset Voicemail Password" option, which will temporarily set your password to your 10-digit phone number. Dial voicemail by holding "1" or by dialing any of the local access numbers across Canada listed here:
Good luck!
06-28-2021 03:10 PM
@Garlandgrace : Are you able to take inbound calls on your cell now? It sounds like maybe you're in the middle of transferring the number.
The self-serve has a voicemail reset function that will reset the password to your 10 digit phone number. But if things are still in transition then things might be a little unpredictable.
06-28-2021 03:07 PM
@Garlandgrace wrote:I cannot reset my voicemail password after migrating house number to cell and therefore can't retrieve my messages.I tried doung self serve but itcsays this number cannot be changed or it doesnt recognize data.
Hello @Garlandgrace
You may need to set up your voicemail with Public Mobile; see this:
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
Voice mail features:
https://www.publicmobile.ca/en/on/get-help/articles?category=phones&subcategory=voicemail-features
