11-12-2020 02:17 PM - edited 01-05-2022 04:06 PM
Voicemail does not come on after the phone rings 4 times, only comes on when the phone is turned off.
11-12-2020 06:49 PM
@Lornesky dial ##21# then ##004# to reset your call forwarding and then try calling your voicemail
11-12-2020 04:14 PM
Even at 5 seconds, it won't go to voicemail?
What happens when you reject the call?
11-12-2020 03:59 PM
I changed it to 30 but it still does not go to voicemail.
11-12-2020 02:56 PM
@Lornesky : your dialer app should have the call forwarding options. Set them to the same number. It's the number that ends in 4001.
11-12-2020 02:43 PM
If you check out this thread, it's a function of time rather than rings. Have you tried letting it go for 30s which seems to be the maximum time?
11-12-2020 02:36 PM
$35.00 per month.
Samsung A8
11-12-2020 02:31 PM
How do you change from 4 rings to 5 rings?
11-12-2020 02:28 PM
Mine takes 5 rings to get to.
What happens if you reject the call?
11-12-2020 02:26 PM
@Lornesky wrote:Voicemail does not come on after the phone rings 4 times, only comes on when the phone is turned off.
What plan are you on?
Verify if you have minutes available.
What make and model of phone?
