04-20-2019 02:17 PM - edited 01-05-2022 04:29 AM
Is it possible to have the time & date of each voicemail announced upon retrieving them that other service providers do?
04-20-2019 02:32 PM
Here's a nice "TELUS Voicemail Quick Reference Guide". Public Mobile and Telus being the same thing, it should be the same for their voicemail options. OK, it's says in the bottom left corner it's from 2015... but it's worth checking if it stayed the same because the chart is so well designed and useful ! ![]()
04-20-2019 02:27 PM
@trishe wrote:Is it possible to have the time & date of each voicemail announced upon retrieving them that other service providers do?
It already does. It says the time before it plays the message.
04-20-2019 02:26 PM
Here are the menu options.
04-20-2019 02:22 PM
I think that if you hit "5" while listening to the message or right after, you will get date and time. I'll keep looking for additional info while you try it ![]()
