Voicemail
01-10-2019 01:19 PM - edited 01-05-2022 03:01 AM
Can't seem to get into my messages. I keep getting a message to contact my service provider. Anyone have any suggestions. Sent a message to the service provider two days ago but they have not responded. Doreen
Phones
01-10-2019 05:10 PM
thanks for the update @jessielibra 🙂
01-10-2019 04:11 PM
Thanks for your help. Got my problem solved.
01-10-2019 02:29 PM
@Jessica_T I'm going to say the same thing to you that I said to @RobertQc the other day. When possible, please try to refrain from copying-and-pasting entire posts when you can link to them instead. Snippets are fine to point out important bits or add context, but ideally just link back to the actual info. In this case, to Shazia_K's posting here: https://productioncommunity.publicmobile.ca/t5/Paying-for-your-service/access-voice-mail-out-of-home...
01-10-2019 01:25 PM - edited 01-10-2019 01:30 PM
@jessielibra wrote:Can't seem to get into my messages. I keep getting a message to contact my service provider. Anyone have any suggestions. Sent a message to the service provider two days ago but they have not responded. Doreen
@jessielibraHow are you dialing voicemail? What happens when you manally dial voicemail? If you been using the built in voicemail shortcut on the phone it may be that voicemail shortcut needs to be edited and when your phone dials voicemail it goes to a provider that does not have a voicemail account for your number. Try to call one of these numbers in your local area if it fixes the problem your voicemail shortcut needs to be edited.
204 (oustide of Winnipeg) 204-588-4002
204 (Winnipeg) 204-588-4001 204-588-4002
226 (226-580-4001)
250 (778-581-4001 778-581-4002)
289 (289-680-4001)
306 (587-580-4002)
403 (587-580-4001 587-580-4002 587-580-4003)
416 (647-580-4001 647-580-4002)
418 (581-580-4001)
438 (438-580-4001)
450 (450-320-4001)
506 (506-588-4001)
514 (438-580-4001)
519 (226-580-4001)
581 (581-580-4001)
587 (587-588-4002)
604 (greater Vancouver area 778-580-4002)
604 (Outside greater Vancouver area 778-580-4003)
613 (613-581-4001)
647 (647-580-4001 647-580-4002)
705 (705-780-4001)
709 902-580-4001
778 (outside greater Vancouver area 778-580-4001)
778 (greater Vancouver area 778-580-4002)
780 (587-588-4001 587-588-4002)
807 (705-780-4001)
819 (819-588-4001)
902 (902-580-4001)
905 (289-680-4001)
The waiting game is the only game to play at public mobile after contacting the moderator team.
