Voicemail Message
tangycandy
So I've just set up my voicemail, and was asked to say my first name, but also create a greeting? Will both of them be used?
tangycandy
I've done this, but wanted to know what the purpose of recording the name was. Luckily, cavemantoronto was able to answer my question.
Stay safe!
tangycandy
Thank you! This is exactly what I wanted to know. 🙂
cavemantoronto
@tangycandy
Name plays if voicemail full. Might be option to use a generic greeting with name too.
gblackma
@tangycandy  probably. A simple way to test it would be yo call and listen to the voicemail. Stay safe.
Triguy
Yes, whatever you record as your greeting will be used.
shep22
@tangycandy hello whatever you say during recording will be used stay safe😁
