Voicemail Limit
evilgabbie
Is there an Addon to increase my voicemail inbox limit ?  I work sales and 10 messages isn't enough.  Please advise.  Thank you !
7 REPLIES 7
JaimeLaPizza
I've just had a look at Fongo.  Quite cool.  You could forward your calls there when they're about to be sent to PM voicemail.  People will record their message in Fongo's voicemail which will then send you an email with an attached audio file containing the caller's voice message.  You can listen to it from your email box or you can go to Fongo's visual voicemail interface where you will see the list of voicemails left by callers and listen to them in any order you wish, save them, delete them...  Certainly worth taking a look at.  I may have missed some downsides though, so be sure to do your homework before you go that way Smiley Very Happy
geopublic
Since it's for work you might want to check out a service that will allow you to receive voicemail via email like youmail.com and voip.ms.
JaimeLaPizza
Call fowarding could help, maybe.
It has different options:
Type of Call Forwarding
What it Does
How to Enable
How to Disable
Unconditional
Redirects all incoming calls to another number.
Dial ‘*21*’ + ten-digit phone number + ‘#’ + SEND
Dial ‘#21#’
Busy
Forwards incoming calls to another number when the line is in use.
Dial ‘*67*’ + ten-digit phone number + ‘#’ + SEND
Dial ‘#67#’
Not Reachable
Redirects incoming calls when your phone is unable to take a call.
Dial ‘*62*’ + ten-digit phone number + ‘#’ + SEND
Dial ‘#62#’
No Reply
Redirects incoming calls when nobody answers.
Dial ‘*61*’ + ten-digit phone number + ‘#’ + SEND
Dial ‘#61#’
Variable
Redirects incoming calls after the call has not been answered for a specified period of time.
Dial ‘*004*’ + ten-digit phone number + ‘#’ + SEND
Dial ‘#004#’
duffer900
From my research the limit is 10 voicemails up to 5 minutes long each. Once you hit 10, it deletes the oldest. This is across all plans
mimmo
No there is not.
You could forward your missed calls to fongo.com (free Canadian number) they have a visual voicemail type interface. Not sure the vm limits there though.
Pizzaeh
No, I don't believe there is an add-on for voicemail inbox limit. However, as @Anonymous has pointed out, there might be services you could use to supplement the 10 message limit.
No.
There are external voicemail services you can use though.
