05-13-2019 03:05 PM - edited 01-05-2022 04:55 AM
I am unable to access voicemail. Phone indicates call failed upon attempt. When I try to update my access number public mobile says I don't have a 'talk' plan so no voicemail. However, I DO have an unlimited talk plan...
05-14-2019 10:59 PM
@ecnivthane wrote:
Thanks! I'll do that
@ecnivthane One more thing i forgot to mention is that others have suggested to reset the network settings on an iPhone to fix similar issues. Might be worth a try while waiting for the moderator to respond.
05-14-2019 04:51 PM
05-14-2019 02:44 PM
@ecnivthane wrote:I think my problem lies with my account set up with public mobile. For some reason the system thinks that I don't have a "talk" plan even though I do, and use it regularly... I have no idea how to contact public mobile directly to resolve. any ideas?
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am (Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm (Eastern).
05-14-2019 02:28 PM
05-14-2019 01:33 PM
@ecnivthane wrote:still wondering how "open phone app and enter that number as the VM number" I don't see where the voicemail access number should be entered...
@ecnivthane That's for Android based phone. iPhones are a different animal?
05-14-2019 01:30 PM
05-13-2019 08:12 PM
@ecnivthane wrote:I am unable to access voicemail. Phone indicates call failed upon attempt. When I try to update my access number public mobile says I don't have a 'talk' plan so no voicemail. However, I DO have an unlimited talk plan...
@ecnivthane This might help for an iPhone 6s:
05-13-2019 08:07 PM
Sorry, Im not sure what you mean? Where do I access that? in settings?
05-13-2019 07:47 PM
@ecnivthane wrote:Thank you, yes, calling +16475804001 allows me to access my voicemail. The voicemail button on my phone (iphone 6S plus) still doesn't work, but at least I can get the mail! thanks again
@ecnivthane Just open yout phone app and enter that number as the VM number and you should br able to access VM from your notification bar
05-13-2019 07:44 PM
05-13-2019 07:33 PM
@ecnivthane wrote:No, I get the same result... just call failed
@ecnivthane What is the make and model of your phone? Can you dial +16475804001 vm directly?
05-13-2019 05:03 PM
05-13-2019 04:55 PM
@ecnivthane wrote:I get through to public mobile
@ecnivthane if you hold down 1 on your phone does it go into VM?
05-13-2019 04:01 PM
05-13-2019 03:55 PM
Here is an article about voicemail.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-voicemail
05-13-2019 03:46 PM
@ecnivthane When you dial 611 on your phone what happens?
