Voice message
hongduong
How to set up voice message and how much is it per month
@hongduong
For limited talk plans, you can purchase $5 talk add on for 500 Canada wide minutes.  Unused minutes roll over to next month.
@hongduong retrieving your messages will count towards your minutes if on the limited minute plans. I'm also on the $15 plan. You can add the TextNow app and use it over WiFi to make/ receive/ send calls and texts within Canada and to and from the US for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter it followed by #  - and you are in your voicemail account - Hang up when you are finished. No minutes used.
hongduong
tks
when I receive the voice message, does it count as the incoming/upcoming minutes
gblackma
@hongduong  its free and here's a link on how to customise your voicemail. Stay safe.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-voicemail
